KB-27220: Authentication error on MS SQL Server.
Why is thre an authentication error when I try to establish connection with an MS SQL Server database?
To fix this, you must use the MS SQL Server’s authentication instead of the Windows’ authentication. To do so, set up a user and a password in the database to  access it via Database in E3.
