KB-29915: Vertical movement in chart’s pens.
How can I configure a chart so that pens perform a bottom-up vertical movement?
To do so, configure the numeric scale in the horizontal axis and the time scale in the vertical axis. Then, on the pens’ properties, link a CurrentTime Demo Tag to the vertical axis’ field and the tags to be plotted in the horizontal axis’ field.
