KB-30058: Setting up an E3Chart’s Y axis to display time and X axis to display values.
How can I set up an E3Chart‘s vertical axis (Y) to display time and its horizontal axis (X) to display values?
To do so, follow these procedures:
  1. Acess the horizontal axis’ properties and, on Scale tab, set it up to display a Numeric scale.
  2. Acess the vertical axis’ properties and enable the Show latest data (Real-time) option on the Scale tab.
  3. Add a pen and, on the Realtime configuration of its Data tab, do the following:
         – Vertical axis link: set the link of a Demo Tag configured as Current Time.
         – Horizontal axis link: set the link of the tag that has the value to be plotted.
         – Disable Use TimeStamp option.
