KB-35149: Converting a string into an integer.
How can I convert a string into an integer?
To do so, you must use Global Manager’s Int function, which converts a string into an integer.
Example of script:
// integer (string)
TagReceivesValue = Int(30.95)
Classificação média - Average rating 1 / 5. Count: 1
