HistTool Library.
The HistTool library is a very simple tool, perfect for quick viewings and small operations on Historics. It was developed to be auto-configurable, thus avoiding time waste when setting up the browser and queries.
With this library, you will be able to:
  • Hide or show the Quality fields.
  • Insert and delete records.
  • Reconfigure the historic’s scan time.
  • Query using a date/time filter.
  • Export the table to an Excel file.
To use this feature, follow these guidelines:
  1. Extract the attached file to your computer (preferablyin the application folder).
  2. In E3Studio, add the library to your domain.
  3. Insert an XcHistTool object onto screen.
  4. Select the Historic on the XcHistTool object’s HistSource property.
Important: to use this tool, there must be a historic already configured in the application.
The attached demo library was developed with Elipse E3 v3.2 b260.
HistToolLib v2.0
