KB-34142: Changing messages in E3Alarms’s Severity field.
How can I display different messages from those defined as default on the E3Alarm‘s Severity field?
To do so, select the Severity field in the E3Alarm‘s properties on Columns tab. Then, click the Properties button, and write the desired messages on the Formatting field, separated by a semicolon. These messages must be written in priority order: high; medium; low.
Thoughts on “KB-34142: Changing messages in E3Alarms’s Severity field.
