KB-33729: Browser not updated automatically.
Why is the data loaded in the Browser not being updated after the application has been executed, thus making it necessary to stop the application and then re-execute it so that the data is finally updated?
Elipse SCADA’s Browser does not update its data automatically. To reload it, you must execute UpdateQuery function. This can be done in WhileRunning event of the screen.
Example: Browser1.UpdateQuery()
