KB-33309: Objects’ color settings via RGB function.
How can colors be set in objects via RGB function?
A possible solution would be to create a Ram tag for each item in RGB (red, green, blue), and then create a script in each tag’s OnValueChanged event to attribute the mix’s RGB to them as follows:
Object.Property = RGB(RedTag, GreenTag, BlueTag)
You can find RGB function in the Global Manager, via AppBrowser.
NOTE: Attached to this article is a sample application illustrating these procedures.
Sample
