KB-29581: Error 8007007F when inserting an E3Alarm.
Why is the following message being displayed when I try to insert an E3Alarm via E3Studio into screen: “Could not create object. Error code 8007007F“? And why is the Properties window from my E3Alarm is blank when I open it? How can I fix it?
To do so, you can close all applications in Elipse E3 (including E3Admin, if v3.0 or higher), and then execute Register.bat file, which is in Bin folder at E3’s installation directory (…\ElipseE3\Bin) . After that, try inserting the E3Alarm into screen again.
