Reading and writing bits with M-Prot driver.
Question:
Can the bit from a digital input be read? Can Bool-type tags be used?
Solution:
No; this can only be done indirectly.
To read/write a single bit, the whole Byte must be read/written (and tag type must be set as Byte), since its input/output is an octet. For example, to write on the third digital output, you must write value 4 on the tag (4 decimal = 100 in binary, therefore the third output bit).
This works for both bit writing as for bit reading. First, you must handle the bit, and tonly then read/write the whole Byte.
Note: In this case, Bool is not a bit. Bool is a byte whose possible meanings are either TRUE or FALSE. If you try to read/write a bit as Bool, it will not work.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
