Question:
Can I animate *.JPG and *.BMP files with the rotation effect?
Solution:
No, you cannot. You can only successfully animate vector figure files with the rotation effect, such as Windows Metafile (WMF).
Before you insert the animation, follow these procedures:
- Right-click on the figur.
- Select the option Convert into Symbol.
If our file was originally a *.JPG or *.BMP that was further converted .WMF, you still will not be able to animate it with the rotation effect. To do so, you must create a new figure and save it in .WMF format.
