KB-40357: Disable Application Switching not working in Windows 7.
Question
How can I set up Elipse SCADA so that the Disable Application Switching option works properly in Windows 7?
Solution
To make sure Disable Application Switching option works properly, Elipse SCADA must be executed as Administrator. To do so, just access the SCADA shortcut properties and choose Run as Administrator option on Compatibility tab.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
