Question:
Which files must be copied for backing up an E3 application?
Solution:
To do so, you must copy the .DOM (Domain), .PRJ (Project), and .LIB (Library) files.
However, it is important to highlight that E3 applications also work with other types of files, such as communication files (.DLL), images (.JPEG, .BMP, etc.), sounds (.WAV), databases (.MDB), and more. When moving an application, you must move them too.
