KB-36501: CurrentTime not displaying Windows’s time.
Question:
Why is a Display showing incorrect date/time when using CurrentTime attribute?
Solution:
This may happen because SCADA’s internal clock is delayed/early in relation to the Windows clock.
To disable SCADA’s internal clock and use Windows’s clock, follow these procedures:
  • On Start menu, select the Execute option and write the command regedit;
  • Open the HKEY_CURRENT_USER\Software\Elipse Software\Elipse32\Options folder;
  • Create a Dword key named DisableInternalClock and set its value to 1.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
