KB-36336: Periodic data discard from a Historic’s table.
Question:
How can I enable data discard from a Historic’s table every 24 hours?
Solution:
To do so, you must enable the Discard data from main table option in the Historic’s properties, set 24 hours in the Keep data from the last field, and configure less than 24 hours in the Discard data every field.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
