Question:
Which driver is used to establish communication with an Altus Piccolo 106 PLC?
Solution:
This PLC uses Altus ALNET I driver (Alnet 1v2 driver). However, if an ethernet module (PO-9902) is being used, you can also use driver Altus ALNET II over TCP/IP (AltusTCPIP driver).
