Question:
Can I read a bar code with a scanner via supervisory?
Solution:
Yes, you can. To do so, the scanner must have a PS2 connection so it can work as a keyboard.
Then, just insert a SetPoint on screen, and read the bar code with the scanner. By doing so, data is written in the SetPoint as if you were using a keyboard.
