Question:
When using Siox driver, why does SCADA display an approximate value of 65535 and not the negative values read in the device?
Solution:
This happens because Siox driver cannot currently support negative values, only WORD-type value (unsigned 16 bits). So, the diver will adapt a signed value to an unsigned type, thus generating this type of variable.
