Question:
How can the objects’ TAB order on a screen be set in an application?
Solution:
The browsing order via TAB button is set according to the order the objects were inserted onto screen; that is, the newer the object, the further back it is sent on the TAB’s order list.
To change this order, you must select the object that needs the focus on the foreground and then click on Bring to Front button.
To organize the whole TAB order, select the first object to receive focus and click on Send to Back button, then do this again with the second object, then the third, the fourth, and so on.
