KB-35527: “Enable Unsolicited on Startup” and “Scans for Events every X ms” options working together.
Question:
Can Enable Unsolicited on Startup and Scans for Events every X ms options on DNP Master driver’s work together?
Solution:
Yes, they can. However, since you may want to have the least amount of data traffic as possible, it is better if they are not enabled at the same time.
Print Friendly, PDF & Email
Deixe seu Comentário
