KB-34924: Reading a VD in an S7-200 via Ethernet.
Question:
How can an S7-200’s VD20 be read via Ethernet with M-Prot driver?
Solution:
To establish communication with an S7-200 CP243 via Ethernet, you must set Network field as ISOTCP243. Tag’s parameters should be:
VD20 Read (uncheck the option Write on the tag)
  • N1=0
  • N2=709 (REAL)
  • N3=1
  • N4=20
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
