KB-34908: Opening an external program when starting the application.
Question:
Can I  open an external program when starting the application?
Solution:
Yes. To do so, use Run Application pick (as seen below). This pick is on Scripts tab, alongside the other picks used in scripts.
To set up this pick, access Scripts tab (in the application’s first screen), select OnStartRunning event  and then Run Application pick, setting up its fields as needed.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
