KB-34488: Setting.VARS file to read and write the Database.
Question:
How can a .VARS file be set to read and write the Database?
Solution:
To do so, use the following syntax:
Cn = DB N POS,TAM
Where:
n = Number of the variable being used in N3/B3
N = Number of the Database
POS = Position of the Database variable to be read
TAM = Number of variables to be read
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
