Question:
Can I set the position of a MessageBox on screen (X and Y coordinates)?
Solution:
No, you can’t. The MessageBox is always displayed in the center of the screen. However, you can create a customized modal screen, with a format similar to the MessageBox’s. In this case, it is possible to set where it is displayed.
