KB-33206: Filter by date not working with string values.
Question:
Why is a filter by date, recorded as a string, not working?
Solution:
For the comparison logic to work (value higher than InitialDate, but lower than FinalDate), the value must be DateTime. If it were recorded as a string, for example, the query would not be able to apply this kind of logic.
If date/time information is a string, you can runVBScript’s CDate() function, which converts the string to DateTime. Then, you will be able to record the correct type of information so that your filter can work properly.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
