KB-33199: DLL/Connection sharing for multiple drivers.
Question:
Can I share a DLL/connection between two or more I/O drivers?
Solution:
Yes. If ShareServer property is set as TRUE, this driver will share its execution between the other drivers sharing the same string in DriverLocation property. This means that only the first configured driver will initialize I/O, while the others will ignore their specific settings and have their tags use the connection already started.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
