KB-32185: Issues when reading RSLinx’s Block Tag via OPC.
Question:
Why can I only read the first element of a RSLinx’s Block Tag via OPC?
Solution:
This happens because the Block Tag is linked to an RSLinx’s simple tag; thus, it will only read the first element.
To avoid this type of problem, we suggest that you always import the server’s tags to the application.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
