KB-30897: Changing a SetPoint into a Display.
Question:
Can I change a SetPoint into a Display, and vice versa?
Solution:
Text, Display, and SetPoint are all the same object, named DrawString. The initial settings of some of their properties is the only difference between them.
To change a SetPoint into a Display (and vice versa), you must edit IsSetPoint property.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
