KB-30529: Error 80004005 when accessing Access database.
Question:
When testing the connection to an Access database, the error 80004005 is displayed. How can I fix this?
Solution:
To do so, check if the *.mdb file path is set up correctly. For example, if instead of C:\ElipseApp\App.dom, there is D:\ElipseApp\App.dom, when the computer has no D unit.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
