Question:
Can two E3 applications run in the same computer?
Solution:
No, they cannot. To work around this issue, you can try one of the following:
- Using two different computers;
- Grouping both applications into a single one; or
- Setting up two applications: one with Elipse E3, and the other with Elipse SCADA.
