KB-30056: Displaying a message when the login is incorrect.
Question:
How can I display a message when the login is incorrect?
Solution:
To do so, you must use a script that tests if the Application’s useName attribute contains any user. In case it doesn’t, the error message must then be displayed via  MessageBox command.
Example of script performed at the button’s OnPress() event:
Application.Logout()
Application.Login()
IF Application.userName <> “”
    MessageBox(“Login performed successfully!”)
ELSE
    MessageBox(“Login incorrect!!!”)
ENDIF
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
