Question:
How can I set a Label object to be displayed vertically?
Solution:
You cannot set a Label to be displayed vertically; however, you can use a Text object (which shares many properties with Label), and then change its Angle property to 90.
NOTE: Attached is a sample application developed with E3 3.1 Build 270.
