KB-29747: Monitoring the communication between Elipse E3 and a PLC.
Question:
How can I set up an alarm to be triggered when the communication between the Elipse E3 and a PLC is offline?
Solution:
There are two different ways to do so:
  1. When the PLC can inform the communication status (via memory, bit, Word, etc), you can read this information via an I/O Tag; or
  2. You can use the IOKit‘s tags and monitor their values according to the Elipse IOKit’s Manual.
After that, you must create a digital alarm pointing to the previously created tag and perform the necessary settings.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
