KB-29704: Opening Viewer in a screen not set up as its initial screen.
Question:
How can I set up the Viewer to be opened in a screen other than the initial screen set in the application?
Solution:
To do so, you must use the following command line on a Viewer’s shortcut: Viewer [server_name] -screen [screenname]
For example:
“C:\Program Files\Elipse Software\Elipse E3\Bin32\E3Viewer.exe” computer1 -screen Screen2
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
