How can I view the Driver’s status?
Solution:
To do so, you must create a tag and configure its parameters as N1=-1, N2=0, N3=0 and N4=2, or import a PhysicalLayerStatus Tag via Tag Browser.
0 – Physical layer stopped (the Driver is offline, the physical layer failed in the start up or exceed the maximum number of connection retries).
1 – Physical layer started, but it is disconnected (the Driver is online, but the physical layer is disconnected. If the connection automatic management is enabled, the physical layer is trying to connect, it is disconnected, or it is waiting for a connection retry. If the connection manual management is enabled, the physical layer continues disconnected until you force it to connect).
2 – Physical layer connected (the physical layer is ready to be used). This does not mean that the device is connected; it just means that the access layer is working.
