KB-29434: Inserting a scrollbar into a display.
Question:
How can I insert a scrollbar into a Display?
Solution:
You cannot insert a scrollbar into a Display. However, you can use a TextBox object to visualize a larger amount of information via scrollbar. To enable the scrollbar in a TextBox, ScrollBars and MultiLine properties must be set as seen below.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
