Question:
Which of the options below is the best choice?
- using an OPC Client with 20 I/O Tags linked to an OPC Server; or
- using 20 OPC Clients, each with an I/O Tag linked to an OPC server.
Solution:
We suggest that you use a single OPC Client with 20 I/O Tags, so E3 will have to create and control a just one connection.
