KB-28857: Opening screens when tags change their values
Question:
How can I open a screen in a splitter whenever a tag changes its value?
Solution:
To do so, you must create a user event in the Viewer whose property/expression is the condition tag=0. In this script (at the user event), use Open Screen pick, and then select the screen and frame to be used.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
