KB-28828: Cropped screen in Windows Vista.
Question:
When an Elipse SCADA application is run in Windows Vista, the right side of the screen appears to have been cropped. Why does this happen?
Solution:
Elipse SCADA’s appearance settings are incompatible with Windows Vista: the edges of the windows opened by the operating system interfere with how SCADA is displayed at runtime. To fix this, you must change Windows’s settings to Classic Windows theme; by doing so, this problem will not happen anymore.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
