Question:
How can I set Windows’ clock via E3 scripts?
Solution:
To do so, use DATE and TIME commands via DOS command line. It can be inserted in a script inside E3, for example, in a button’s Click event.
Sub CommandButton1_Click()
    Set oShell = CreateObject("WSCript.shell")
    'Changes date
    oShell.run "cmd /K DATE "&DD&"/"&MM&"/"&AAAA,0
    'Changes time
    oShell.run "cmd /K TIME "&HH&":"&mm&":"&ss,0
    Set oShell = Nothing
