Question:
How can I add a Driver to an XObject, and also allow access to its properties when the XObject is inserted in the project?
Solution:
To do so, you must create properties in the XObject linked to the Driver’s properties that you want to access. After inserting the XObject in the project, these properties must be set up as if they were being set up directly in the Driver.
