Question:
How can I export screens from Elipse SCADA to Elipse E3? Are scripts exported too?
Solution:
To do so, access Elipse SCADA, open the Organizer (Alt+O), select the desired screen, and click the Export button. Having done that, open the E3Studio and insert a screen in the desired project. Then, right-click on it and click the Import option. Finally, just change the file type to Elipse SCADA Files (*.E2F) and import the screen.
NOTE: The screen’s scripts are not exported by this procedure.
