KB-28321: Objects’ position and size change when the application is executed.
Question:
Why do some objects’ position and size change from what was set up in E3Studio when the application is executed?
Solution:
This happens when the screen and the Frame where it is being opened have different sizes and the Fill in zoom option is enabled. To fix the problem, you must set the zoom to 100% or use the Fit to splitter… option of the Screen’s context menu.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
