KB-28296: Maximum amount of Historic fields when using Access DB.
Question:
What is the maximum amount of Historic fields when using Access DB?
Solution:
You can use up to 127 fields: for each field created in the Historic, another one is created in Quality field.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
