KB-28076: Removing blank spaces from a variable.
Question:
How can I remove blank spaces from a variable? For example, the text “Elipse Software Ltd.” is in a variable, but I want to display “ElipseSoftwareLtd.” instead.
Solution:
To do so, you can write the following script:
Dim aux, tmp, auxValue
tmp = Len(WithBlankSpaces)
WithoutBlankSpaces = “”
for aux = 0 to tmp – 1
auxValue = Mid(WithBlankSpaces,aux,1)
If auxValue <> ” “
WithoutBlankSpaces = WithoutBlankSpaces + auxValue
Endif
Next
In this script, WithBlankSpaces is a RAM Tag that receives the original text (in this case, “Elipse Software Ltd.”), and WithoutBlankSpaces is the RAM Tag that receives the script’s result (in this case, “ElipseSoftwareLtd.”).
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
