Question:
How can I active a Button’s Click() event by right-clicking on it?
Solution:
To do so, you must write a script on the Button’s MouseUp event to check when the Button parameter’s value is equal to 2 (indicating that it is the right button). For example:
Sub CommandButton1_MouseUp(Button, Shift, X, Y)
IF Button = 2 then
MsgBox “Event fired!”
END IF
