KB-27701: Editing an E3Chart’s axis at run time.
Question:
How can I edit an E3Chart‘s vertical axis at run time?
Solution:
This can’t be done.
Therefore, you must create a new axis, via AddAxis method.
Example: Screen.Item(“E3Chart1”).Axes.AddAxis “NewAxisName”
After that, you can change each pen’s axes via ScaleY property.
Example: Screen.Item(“E3Chart1”).Pens.Item(“Pen1”).ScaleY = “NewAxisName”
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
