Question:
Can I change the objects’ activation order in the domain?
Solution:
Yes. To do so, access the E3Studio, load the domain, and select the option Edit Activation Order, by right-clicking the domain.
Having done that, the Domain Activation Order window will open, were each project and its objects will be displayed separately. To change the activation order, just select the desired object or project and click the options to the right. The objects higher on the list are the first to be activated once the domain is executed.
