KB-27342: Displaying Flash animations in Elipse E3.
Question:
How can a Flash animation (SWF files) be displayed in Elipse E3?
Solution:
To do so, you must insert the path (example: c:\FilesFlash\test.swf) of the SWF file to a Frame’s SplitLink property and then open it in the Viewer.
Another possibility is to use the  MicrosoftWebBrowser ActiveX and set it up to open the swf file.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
