KB-27233: Changing the color of an E3Chart’s pens at run time.
Question:
How can I change the color of an E3Chart’s pens at run time?
Solution:
To do so, you must create a script using E3 Viewer’s ShowPickColor method to set the value of the pen’s Color property. For example:
Application.ShowPickColor color
if RowData = 0 then
    'passes the selected color to the pen
    Screen.Item("E3Chart1").Pens.Item("Pen1").Color = color
else
    Screen.Item("E3Chart1").Pens.Item("Pen2").Color = color
end if
For more details, check the attached demor application developed on E3 version 3.2 build 260.
Change_Pen.zip
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
